[osgeo4w-dev] [osgeo4w] #87: ogr2ogr: issue with filename of Pgeo type
OSGeo4W trac_osgeo4w at osgeo.org
Fri May 15 07:02:58 EDT 2009
Reporter:  pibinko  |       Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect   |      Status:  new
Priority:  minor    |   Component:  Package
 Version:           |    Keywords:
 It seems that ogr2ogr (v 1.5.4-2) does not accept filenames of personal
 geodatabases with short filenames, or containing numbers in the filename..
 a) here is the error:
 ERROR 1: Unable to initialize ODBC connection to DSN for cipaaaa1,
 [Microsoft][ODBC Driver Manager] Data source name not found and no default
 drive
 r specified
 FAILURE:
 Unable to open datasource `Pgeo:cipaaaa1' with the following drivers.
 b) I did some tests...it seem the issue related to MDB files..
 - with file names less than 3 characters in length
 - with file names containing a number (any length)..
 a.mdb fail
 ab.mdb fail
 abc.mdb OK
 a1.mdb fail
 abc1.mdb fail
 abcedfg1.mdb fail
 ...clearly: I can't say if this is an exhaustive set of tests, but I hope
 it can help
 the issue can be bypassed by renaming the MDB file, so I am giving this a
 minor priority
 regards
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/87>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
