[osgeo4w-dev] MapFish setup: conflict with simplejson 2.0.5
Lucena, Ivan ivan.lucena at pmldnet.com
Tue May 19 09:30:37 EDT 2009
Hi there,
Selecting MapFish, OSGeo4W installer just creates folders with several installers on:
E:\OSGeo4W\apps\mapfish_framework-1.0\scripts
E:\OSGeo4W\apps\mapfish_framework-1.0\site-packages
Besides that I believe you are on your own. Is that right?
But I found instructions on how to install MapFish on a OSGeo4W environment at:
http://www.mapfish.org/trac/mapfish/wiki/HowToInstallMapFishServerFrameworkInOsgeo4w
That doesn't look to be in sync with current settings on the installer. It doesn't use the downloaded installer from
'apps\mapfish_framework-1.0' but it downloads from the MapFish trunk. Developer-instruction != User-Instruction of
course.
But following the instructions I got stuck on that error:
E:\OSGeo4W\apps\mapfish_framework\server\python>easy_install dist/mapfish-1.2dev-py2.5.egg
Processing mapfish-1.2dev-py2.5.egg
removing 'e:\osgeo4w\apps\python25\lib\site-packages\mapfish-1.2dev-py2.5.egg' (and everything under it)
creating e:\osgeo4w\apps\python25\lib\site-packages\mapfish-1.2dev-py2.5.egg
Extracting mapfish-1.2dev-py2.5.egg to e:\osgeo4w\apps\python25\lib\site-packages
mapfish 1.2dev is already the active version in easy-install.pth
Installed e:\osgeo4w\apps\python25\lib\site-packages\mapfish-1.2dev-py2.5.egg
Processing dependencies for mapfish==1.2dev
error: Installed distribution simplejson 2.0.5 conflicts with requirement simplejson>=2.0.8
I tried easy_install with "-D" to delete conflictings packages but that didn't help.
Does anybody have a clue of what would be the solution for that?
Regards,
Ivan
More information about the osgeo4w-dev mailing list
