Re: [osgeo4w-dev] MapFish setup: conflict with simplejson 2.0.5
Lucena, Ivan ivan.lucena at pmldnet.com
Tue May 19 09:44:39 EDT 2009
Answering my own question with another question:
What part of easy I didn't get, the E or the Z? :)
That fixed the problem:
E:\OSGeo4W\apps\mapfish_framework\server\python>easy_install --upgrade simplejson
E:\OSGeo4W\apps\mapfish_framework\server\python>easy_install dist/mapfish-1.2dev-py2.5.egg
Regards.
>  -------Original Message-------
>  From: Lucena, Ivan <ivan.lucena at pmldnet.com>
>  Subject: [osgeo4w-dev] MapFish setup: conflict with simplejson 2.0.5
>  Sent: May 19 '09 08:30
>  Hi there,
>  Selecting MapFish, OSGeo4W installer just creates folders with several installers on:
>  E:\OSGeo4W\apps\mapfish_framework-1.0\scripts
>  E:\OSGeo4W\apps\mapfish_framework-1.0\site-packages
>  Besides that I believe you are on your own. Is that right?
>  But I found instructions on how to install MapFish on a OSGeo4W environment at:
>  http://www.mapfish.org/trac/mapfish/wiki/HowToInstallMapFishServerFrameworkInOsgeo4w
>  That doesn't look to be in sync with current settings on the installer. It doesn't use the downloaded installer
from
>  'apps\mapfish_framework-1.0' but it downloads from the MapFish trunk. Developer-instruction != User-Instruction
of
>  course.
>  But following the instructions I got stuck on that error:
>  Processing mapfish-1.2dev-py2.5.egg
>  removing 'e:\osgeo4w\apps\python25\lib\site-packages\mapfish-1.2dev-py2.5.egg' (and everything under it)
>  creating e:\osgeo4w\apps\python25\lib\site-packages\mapfish-1.2dev-py2.5.egg
>  Extracting mapfish-1.2dev-py2.5.egg to e:\osgeo4w\apps\python25\lib\site-packages
>  mapfish 1.2dev is already the active version in easy-install.pth
>  Installed e:\osgeo4w\apps\python25\lib\site-packages\mapfish-1.2dev-py2.5.egg
>  Processing dependencies for mapfish==1.2dev
>  error: Installed distribution simplejson 2.0.5 conflicts with requirement simplejson>=2.0.8
>  I tried easy_install with "-D" to delete conflictings packages but that didn't help.
>  Does anybody have a clue of what would be the solution for that?
>  Regards,
>  Ivan
>  _______________________________________________
>  osgeo4w-dev mailing list
>  osgeo4w-dev at lists.osgeo.org
>  http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev mailing list
