[osgeo4w-dev] [osgeo4w] #107: grass (v.patch) need libintl-8.dll
OSGeo4W trac_osgeo4w at osgeo.org
Sun Sep 27 18:34:50 EDT 2009
Reporter:  jdenisgiguere  |       Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect         |      Status:  new
Priority:  major          |   Component:  Package
 Version:                 |    Keywords:  grass libintl-8.dll
 Trying to use grass 6.4.0-svn3 from osgeo4w using Windows Vista, I get the
 following error message:
 "The application has failed to start because libintl-8.dll was not found.
 Re-installing the application may fix this problem."
 Are there known workarounds?
 Is there a package from which I could install missing file.
 Best regards,
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/107>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
