[osgeo4w-dev] Python GIS programming environment under Windows
Alex Mandel tech_dev at wildintellect.com
Wed Dec 15 13:02:31 EST 2010
I've managed to get IDLE, Pythonwin, ERIC and SPE(My Favorite) to work
with OSGeo4W before. It'll take me a day to dig up the material though.
It does indeed require setting the environment variables properly before
you open the app. Here's my Pythonwin example
http://osprey.ucdavis.edu/downloads/abt182/OSGeo4Wpythonwin.bat
Enjoy,
Alex
On 12/15/2010 09:27 AM, Matt Wilkie wrote:
> Thank you for the kind words Gilles.
> It's so easy to focus on the immediate problem and de-emphasize, by
> omission, the gifts that enabled us to have the issue in the first place
> (something I'm frequently quilty of. So it's good to be reminded :)
>> This application has failed to start because MSVCR71.dll was not found.
> This should be installed as part of the msvcrt package in
> %osgeo4w_root%\bin. Msvcrt package is a root package and should always
> be there no matter what options are selected on install. You likely need
> to set the environment with OSGeo4W.bat before calling pythonwin (or use
> that batch file as a template for permanently setting the system
> variables).
>> I'm thinking of installing Python/IDLE separately but I'm not sure it
>> will be able to find/use packages from the osgeo4w stack.
> From http://trac.osgeo.org/osgeo4w/ticket/114 there's a python script to
> (de)register a python directory tree in the windows registry. It doesn't
> work on 64 bit systems (patches welcome). After using register-python.py
> you should be able to use the standard windows installers for any python
> application not included in Osgeo4w.
> In my view this is a better route forward than packaging yet another
> not-really-gis program into the osgeo4w mirror system. We already have
> enough difficulty keeping the core packages up to date. :)
> cheers,
> matt wilkie
> Geomatics Analyst
> Information Management and Technology
> Yukon Department of Environment
> 10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
> 867-667-8133 Tel * 867-393-7003 Fax
> http://environmentyukon.gov.yk.ca/geomatics/
> On 15/12/2010 2:17 AM, Gilles Bassière wrote:
>> Hi,
>> I'm new to this list and before anything else I would like to thank the
>> people behind OSGeo4W for their work. I believe it makes OSGeo projects
>> much more accessible to common GIS users.
>> For the purpose of a GIS programming lab, I'm trying to get up and
>> running the following: Python, a Python IDE and several libraries
>> (primarily GDAL/OGR and Mapnik but also Geopy).
>> Regarding the IDE, I don't have specific requirements, I merely want to
>> avoid using cmd.exe because this might frighten my students :) IDLE
>> would be fine for example but I can't find it in the OSGeo4W components.
>> I see that Pythonwin is present but I get this error when I launch it:
>> I did try to re-install python-win32 but it doesn't help (my test
>> platform is Windows XP within a VirtualBox).
>> I'm looking for advices about the easiest way to get a Python GIS
>> programming environment under Windows.
>> Best regards
More information about the osgeo4w-dev mailing list
