[osgeo4w-dev] Python GIS programming environment under Windows
Jürgen E. Fischer jef at norbit.de
Thu Dec 16 04:25:18 EST 2010
Hi Gilles,
On Thu, 16. Dec 2010 at 10:21:12 +0100, Gilles Bassière wrote:
> After a little more investigations, this didn't seem to be a bug to me.
> It looks more like a design choice. Indeed, I can't find any instruction
> to put %OSGEO4W_ROOT%\apps\gdal-17\pymod on the Python path in the
> etc\ini\*.bat files. Also, I've seen examples of user explicitly
> modifying the Python path:
> - http://code.google.com/p/maptiler/source/browse/trunk/setup.py?r=13
> - Alex's batch file
The default GDAL is still 1.5.  If you want GDAL 1.7 you need to call
gdal17.bat from your batch file (qgis does that too in it's batchfile).
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev mailing list
