[osgeo4w-dev] Python GIS programming environment under Windows
Thu Dec 16 12:12:55 EST 2010
On 10-12-16 11:47 AM, Howard Butler wrote:
> On Dec 15, 2010, at 11:27 AM, Matt Wilkie wrote:
>>  From http://trac.osgeo.org/osgeo4w/ticket/114 there's a python script to (de)register a python directory tree in the windows registry. It doesn't work on 64 bit systems (patches welcome). After using register-python.py you should be able to use the standard windows installers for any python application not included in Osgeo4w.
> Making that an advanced installable OSGeo4W package might not be such a bad idea.  This is a common problem.
Howard / Matt,
My main concern with having such a package is that folks sometimes still
do "install all" and would end up applying this change.  But I would like
to see this need provided for.
Best regards,
More information about the osgeo4w-dev mailing list
