[osgeo4w-dev] Re: [osgeo4w] #43: change default setup cache dir to %OSGEO4W_ROOT%\var\cache\setup\
OSGeo4W trac_osgeo4w at osgeo.org
Tue Feb 9 16:50:03 EST 2010
Reporter:  maphew       |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  enhancement  |       Status:  closed
Priority:  major        |    Component:  Installer
 Version:               |   Resolution:  wontfix
Keywords:  setup, apt   |
Changes (by maphew):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 better to go the other way around, have apt use ./var/cache/setup/last-
 cache the same as setup.exe
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/43#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
