[osgeo4w-dev] georaster plugin
Pasta Bolognese pasta.bolognese at gmail.com
Thu Jul 8 11:53:19 EDT 2010
Thanks Ivan, it is working now !
On Thu, Jul 8, 2010 at 4:29 PM, Ivan Lucena <ivan.lucena at pmldnet.com> wrote:
> That is funny. Why did OSGeo4w installed a oci.dll into your system?
> It should use the oci.dll that comes with your Oracle installation. Right?
> Can you rename or remove the two files oci.dll under C:\OSGeo4w folder to
> some other name and try again?
> What is the version of your Oracle installation?
>  > -------Original Message-------
>  > From: Pasta Bolognese
>   > To: Ivan Lucena
>  > Subject: Re: [osgeo4w-dev] georaster plugin
>  > Sent: Jul 08 '10 10:12
>  > oo... I missed it !
>  > now I can see the georaster but I cannot connect to the DB... (using
>  > sqrirelsql I can connect to it...)
>  > if I run the simplest command:
>  > C:\>gdalinfo georaster:login/password at mymachine
>  > ERROR 1: ORA-12514: TNS:listener does not currently know of service
>  > requested in connect descriptor
>  > gdalinfo failed - unable to open georaster:login/password at mymachine'.
>  > (I can connect using other clients and OCI.DLL is there)
>  > C:\OSGeo4W>dir oci.dll /s
>  >  Volume in drive C has no label.
>  >  Volume Serial Number is 2079-A57D
>  >  Directory of C:\OSGeo4W\apps\gdal-16\bin\gdalplugins
>  > 29/08/2005 20:47          344,064
> oci.dll
>  >               1 File(s)
>      344,064 bytes
>  >  Directory of C:\OSGeo4W\bin
> oci.dll
>  >               1 File(s)
>      344,064 bytes
>  >     Total Files Listed:
>  >               2 File(s)
>      688,128 bytes
>  >               0 Dir(s)
> 461,285,158,912 bytes free
>  > C:\>gdalinfo --version
>  > GDAL 1.6.3, released 2009/11/19
>  > C:\>gdalinfo --format georaster
>  > Format Details:
>  >  Short Name: GeoRaster
>  >  Long Name: Oracle Spatial GeoRaster
>  >  Help Topic: frmt_georaster.html
>  >  Supports: Create() - Create writeable dataset.
>  >  Supports: CreateCopy() - Create dataset by copying another.
>  >  Creation Datatypes: Byte UInt16 Int16 UInt32 Int32 Float32 Float64
>  > CFloat32 CFloat64
>  > default="(RASTER MDSYS.SDO_GEORASTER)"/>
>  > default="(SDO_GEOR.INIT())"/>
>  > default="256"/>
>  > default="256"/>
>  > default="Bands"/>
>  > default="0"/>
>  >    BAND
>  >    PIXEL
>  >    LINE
>  >    BSQ
>  >    BIP
>  >    BIL
>  >    JPEG-F
>  >    DEFLATE
>  > C:\>ogrinfo --formats
>  > Supported Formats:
>  >  -> "OCI" (read/write)
>  >  -> "ESRI Shapefile" (read/write)
>  >  -> "MapInfo File" (read/write)
>  >  -> "UK .NTF" (readonly)
>  >  -> "SDTS" (readonly)
>  >  -> "TIGER" (read/write)
>  >  -> "S57" (read/write)
>  >  -> "DGN" (read/write)
>  >  -> "VRT" (readonly)
>  >  -> "REC" (readonly)
>  >  -> "Memory" (read/write)
>  >  -> "BNA" (read/write)
>  >  -> "CSV" (read/write)
>  >  -> "GML" (read/write)
>  >  -> "GPX" (read/write)
>  >  -> "KML" (read/write)
>  >  -> "GeoJSON" (read/write)
>  >  -> "Interlis 1" (read/write)
>  >  -> "Interlis 2" (read/write)
>  >  -> "GMT" (read/write)
>  >  -> "SQLite" (read/write)
>  >  -> "ODBC" (read/write)
>  >  -> "PGeo" (readonly)
>  >  -> "OGDI" (readonly)
>  >  -> "PostgreSQL" (read/write)
>  >  -> "MySQL" (read/write)
>  >  -> "XPlane" (readonly)
>  >  -> "AVCBin" (readonly)
>  >  -> "AVCE00" (readonly)
>  >  -> "Geoconcept" (read/write)
>  > On Thu, Jul 8, 2010 at 3:35 PM, Ivan Lucena <[LINK:
>  > mailto:ivan.lucena at pmldnet.com] ivan.lucena at pmldnet.com> wrote:
>  > Did you executed step #18?
>  > Could you please try that sequence of commands:
>  > C:\> gdal16
>  > C:\> gdalinfo --version
>  > C:\> gdalinfo --format georaster
>  > C:\> ogrinfo --formats
>  > It would be helpful if you could copy and paste the results on your
> next
>  > reply.
>  > Thanks.
>  > >  From: Pasta Bolognese <[LINK: mailto:pasta.bolognese at gmail.com]
>  > pasta.bolognese at gmail.com>
>  > >  To: [LINK: mailto:osgeo4w-dev at lists.osgeo.org]
>  > >  Subject: [osgeo4w-dev] georaster plugin
>  > >  Sent: Jul 08 '10 04:19
>  > >  Hi All,
>  > >  I have installed the georaster plugin as explained in [LINK:
>  > >  [LINK:
> http://www.oracle.com/technology/products/spatial/text/gdal_howto_compile_windows.txt
>  > >  [LINK:
>  > but
>  > >  for some reason the plugin is not there.
>  > >  ERROR 1: --format option given with format 'georaster', but
>  > that
>  > >  format not
>  > >  recognised.  Use the --formats option to get a list of
> available
>  > formats,
>  > >  and use the short code (ie. GTiff or HFA) as the format
> identifier.
>  > >  any ideas ?
>  > >  thanks
>  > >  _______________________________________________
>  > >  osgeo4w-dev mailing list
>  > >  [LINK: compose.php?to=[LINK: mailto:osgeo4w-dev at lists.osgeo.org]
>  > >  [LINK: [LINK:
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev]
>   > >  [LINK: http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev]
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20100708/9522c88c/attachment-0001.html
More information about the osgeo4w-dev mailing list
