[osgeo4w-dev] Re: [osgeo4w] #158: apt uses up all memory and errors out during postinstall
OSGeo4W trac_osgeo4w at osgeo.org
Tue Mar 9 18:54:15 EST 2010
Reporter:  maphew  |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect  |       Status:  closed
Priority:  major   |    Component:  Installer
 Version:          |   Resolution:  fixed
Keywords:  apt     |
Changes (by maphew):
  * status:  new => closed
  * resolution:  => fixed
  * summary:  textreplace memory error => apt uses up all memory and errors
Comment:
 I was not reading the output carefully enough, textreplace was the last
 SUCCESSFUL command. The real problem was infinite regex recursion in `def
 postinstall()`. Fixed in r1156.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/158#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
