[osgeo4w-dev] Re: [osgeo4w] #161: gdal utilities issues
OSGeo4W trac_osgeo4w at osgeo.org
Tue Mar 16 09:04:07 EDT 2010
Reporter:  lutra                 |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect                |       Status:  new
Priority:  major                 |    Component:  Package
 Version:                        |   Resolution:
Keywords:  gdal, gdal utilities  |
Comment (by brushtyler):
 Replying to [ticket:161 lutra]:
 > *) under windows XP all the tools that are in the form of .exe files
 work fine (both from  the command line and from the plugin)
 > [[BR]]
 > *) the same tools under Vista/Seven return errors (both from  the
 command line and from the plugin) like
 > "gdalinfo.exe has stopped working"
 > or
 > "gdalbuildvrt.exe has stopped working"
 > eventually they produce the correct output
 All the executables (.exe) from gdal16 crash in Vista/Seven,
 instead the same tools from gdal lib work fine.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
