[osgeo4w-dev] Re: [osgeo4w] #161: gdal utilities issues
OSGeo4W trac_osgeo4w at osgeo.org
Thu Mar 18 10:55:52 EDT 2010
Reporter:  lutra                 |        Owner:  osgeo4w-dev at lists.osgeo.org
    Type:  defect                |       Status:  new
Priority:  major                 |    Component:  Package
 Version:                        |   Resolution:
Keywords:  gdal, gdal utilities  |
Comment (by jef):
 Replying to [comment:24 jef]:
 > 1. Looks like the GDAL 1.6 GRASS plugin causes that problem.  Maybe
 because GDAL 1.6 was rebuild and the GRASS plugin was not.  Try to rename
 or remove {{{%SOGEO4W_ROOT%\apps\gdal-16\bin\gdalplugins\gdal_GRASS.dll}}}
 to verify (QGIS trunk doesn't need it anymore).
 I've rebuild the GDAL GRASS plugin.  Please test if an upgrade using {{{
 osgeo4w-setup -t}}} helps.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/161#comment:25>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
