[osgeo4w-dev] Unattended install
Matt Wilkie matt.wilkie at gov.yk.ca
Fri May 7 13:02:10 EDT 2010
Hi Jeremy,
On the server I notice there is a setup.ini as well as setup.ini.bz2.
Perhaps both need to be present?
Another option for unattended install is with apt command line installer
(http://trac.osgeo.org/osgeo4w/wiki/pkg-apt). It doesn't do everything
that setup.exe does, but so far works well enough for what I've thrown
at it.
best regards,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
More information about the osgeo4w-dev mailing list
