[osgeo4w-dev] Re: [osgeo4w] #178: QGIS 1.5/dev does not start anymore under XP + 64bit issues
OSGeo4W trac_osgeo4w at osgeo.org
Thu Sep 9 13:41:28 EDT 2010
Reporter:  lutra     |       Owner:  osgeo4w-dev@…
    Type:  defect    |      Status:  new
Priority:  critical  |   Component:  Package
 Version:            |    Keywords:
Comment(by lutra):
 > when it comes to choose what packages/libraries to install, the
 installer does not marks automatically the dependencies, so it makes very
 hard to make a correct installation.
 this problem does not appear when installing osgeo4w under Seven 64bit
 > I miss to test how it works under Windows Seven 64bit, test that I will
 do in the next hours.
 it works fine, no problems at all, as under Seven 32 bit.
 I'm puzzled about the situation under Windows XP. In all the machines I
 tested I'm experiencing the above problems (never seen before... and I've
 installed qgis hundred of times), while I've been told by another person
 that it seems to still install/work fine.
 I believe/suggest more tests under XP.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/178#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer for the OSGeo stack.
More information about the osgeo4w-dev mailing list
