[osgeo4w-dev] mscvr90
Tamas Szekeres szekerest at gmail.com
Sat Aug 27 14:36:14 EDT 2011
Hi Martin,
Some time ago I wrote a blogpost about the issues related to the CRT
runtime, including the problems with the manifest files:
http://szekerest.blogspot.com/2010/02/redistribution-of-shared-c-runtime.html
In this particular case you may either check whether the VC2008
redistributable package has properly been installed on the system or whether
the manifest information (describing the CRT dependecy) is available for the
dll loader. The manifest information can be placed along with the executable
or better yet it can be embedded as a resource in the executable during the
compilation.
Best regards,
Tamas
2011/8/27 Martin Landa <landa.martin at gmail.com>
> Hi,
> after the last update of my OSGeo4W environment I have problem with
> compiling GRASS. First it complained about missing mscvr90.dll, then
> about mscvp90.dll. I have downloaded both files from
> http://dll-files.com and put them to osgeo4w\bin. Unfortunately it
> didn't helped a lot, see error message [1].
> Do you know how to fix this issue? Thanks in advance, Martin
> [1] http://josef.fsv.cvut.cz/~landa/python-error.png
> Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
URL: http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20110827/4db006d7/attachment.html
More information about the osgeo4w-dev mailing list
