[osgeo4w-dev] Significant Problems installing QGIS
Matt Wilkie
matt.wilkie at gov.yk.ca
Mon Jan 31 19:14:48 EST 2011
Ahhh, there's a simpler route: download a new version of
osgeo4w-setup.exe from the website and use that.
(http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe)
((looks like I need to figure out how to get a newer python library of
tarfile and bzip2 for apt.py))
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
On 31/01/2011 4:12 PM, Matt Wilkie wrote:
> Now verified. Same problem exists for package gdal15 and probably others.
> The solution, as indicated in ticket #101, is to repack the archives
> using msys tar & bzip2 and update the setup.ini md5 sums accordingly.
> Jeff I advise you wait a bit until the server files are updated.
> Frank: I am assuming you will regenerate the packages?
> matt wilkie
More information about the osgeo4w-dev
