[osgeo4w-dev] Mapnik in osgeo4w
Roel Vanhout roel.vanhout at gmail.com
Mon May 2 10:16:48 EDT 2011
I didn't know about existing tickets but that's the reason I'm popping
up here :)
#218 looks like exactly what I'll be working on, albeit not
specifically for osgeo4w; but I'd be happy to work with you to fix
this. Are you the mapnik maintainer for osgeo4w? How does it work in
general, are there specific people responsible for specific packages,
or is it one for all and all for one?
In the mapnik trac itself, there are #122 and #410 that seem related;
is anyone here affiliated with those?
I saw your mail to the mapnik mailing list back then, I'll look into
this; part of my work will be on making the api consistent, including
across bindings.
A more general question: do the osgeo4w packages focus on cygwin/mingw
or Visual Studio builds, too? Is there an introduction I can read for
devs to get up to speed, apart from the trac wiki
cheers,
roel
On Mon, May 2, 2011 at 4:06 PM, Julien Malik <julien.malik at c-s.fr> wrote:
> Hello,
> First of all : congratulations for your GSoC project !
> I'm probably whipping a dead horse here, but I hope one of the results of
> your work will be having a solution to the #218 ticket (being able to use
> the mapnik C++ API with only osgeo4w packages).
> We also ran into troubles setting up fonts files necessary for mapnik to
> render its map. If those can be integrated to the mapnik binary package with
> some sort of default paths management so that we don't have to bother with
> these from external projects, that would be great... A related report here :
> https://lists.berlios.de/pipermail/mapnik-users/2011-February/003955.html
> Good luck for your project !
> Julien
> Le 02/05/2011 15:32, Roel Vanhout a écrit :
>> Dear all,
>> I'm a student who's been accepted into Google Summer of Code to work
>> on mapnik, and specifically the build system and builds for Windows.
>> We discussed the inclusion of mapnik in osgeo4w and I'd like to get
>> into contact with the maintainer of mapnik package in there, to see if
>> there's any work we can share/reuse. Thanks!
>> cheers,
>> roel
>> osgeo4w-dev mailing list
>> osgeo4w-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev mailing list
