[osgeo4w-dev] Re: [osgeo4w] #219: Upgrade python version
Jürgen E. Fischer jef at norbit.de
Mon May 2 15:57:09 EDT 2011
Hi Matt,
On Fri, 29. Apr 2011 at 00:18:40 -0700, Matt Wilkie wrote:
> I've started a wiki page where we can more easily track what stage(s) the
> packages are at. (At least I hope it's more easily, the table syntax quickly
> gets cumbersome!)
> http://trac.osgeo.org/osgeo4w/wiki/RequiresPython
> I'll start culling the obsoletes, thanks for point that out Jurgen.
I've seen that you added a comment to the ticket - I still can't login.
I were going to proceed with the update, I'd opt for setting up a secondary
repository (osgeo4w-setup has an option -s to point to a different rep for
testing - not sure about apt).
We could then put the new python there and start migrating the rest - without
any disturbance to the main repository.  Once we're content with the new
repository, we just need to move the new packages to the original repository...
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the osgeo4w-dev mailing list
