[osgeo4w-dev] Dependencies for gdal not installed on 64-bit machines
Jérôme Cuinet jerome.cuinet at cose.fr
Wed Sep 21 04:21:17 EDT 2011
Several months ago, this problem has appeared also on my Windows XP 64-bits
machine. Since, I have given up the osgeo4w installation and I have been
using standalone setup.
>See "AptFromScratch" on http://trac.osgeo.org/osgeo4w/wiki/pkg-apt
I follow Matt Wilkie instructions, and command line setup is OK.
On my other machine Windows XP 32 bits, osgeo4w is all OK (but I use almost
my XP 64 bit machine).
So the problem seems to be in the graphic dependencies interface, unless
this graphic interface don't use the same line commands apt...
Best regards,
Jérôme Cuinet
> -----Message d'origine-----
> De : osgeo4w-dev-bounces at lists.osgeo.org [mailto:osgeo4w-dev-
> bounces at lists.osgeo.org] De la part de Frank Warmerdam
> Envoyé : mardi 20 septembre 2011 23:54
> À : Charles Karney
> Cc : osgeo4w-dev at lists.osgeo.org
> Objet : Re: [osgeo4w-dev] Dependencies for gdal not installed on 64-bit
> machines
> Charles,
> I've seen this from time to time too but it does not seem
> to be specifically due to the 64bitness of the machine.
> I was never able to figure it out though.
> Best regards,
> On Tue, Sep 20, 2011 at 2:49 PM, Charles Karney <charles.karney at sri.com>
> wrote:
> > I can't get OSGeo4W to work on a 64-bit machine at all.  Here are the
> > steps I take
> >  Delete existing C:/OSGeo4W
> >  Download and run osgeo4w-setup.exe
> >  Select express install and uncheck all packages but GDAL
> >  Select install
> >  Start an OSGeo4W shell
> >  Run "gdalinfo"
> > I then get
> >  "The application has failed to start because ogdi_32b1.dll was not
> >  found."
> > Other observations:
> > * the above steps work OK on a 32-bit machine
> > * the installation appeared to install only 2 gdal packages (3 dlls).
> >  On the 32-bit machine several packages were installed alongside gdal
> >  (45 dlls).
> > It seems that the whole dependency mechanism is non-functional on
> > 64-bit machines?
> > Any help would be appreciated.
> > SRI International, Princeton, NJ 08543-5300
> > Tel: +1 609 734 2312
> > osgeo4w-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
More information about the osgeo4w-dev mailing list
