[osgeo4w-dev] #279: Create FileGDB plugin for gdal-19
Matt Wilkie matt.wilkie at gov.yk.ca
Fri Apr 27 15:21:43 EDT 2012
(replying to list instead of Trac to turn down the noise)
Thanks for putting this package together!
I get an error using this on our v9.3 geodatabases:
    B:\> ogrinfo z:\v4\ENV_1000k.gdb
    ERROR 1: Error: Failed to open Geodatabase (This release of the
    GeoDatabase is either invalid or out of date.)
It opens a v10 gdb but doesn't list contents:
    B:\> ogrinfo z:\v5\ENV_50k.gdb
    INFO: Open of `z:\v5\ENV_50k.gdb'
           using driver `FileGDB' successful.
I expected something more like the personal-gdb results (though maybe
this an ogrinfo thing and not a file-gdb thing):
    B:> ogrinfo z:\Geodatabase\admin1000k.mdb
    INFO: Open of `z:\Geodatabase\admin1000k.mdb'
           using driver `PGeo' successful.
    1: Yukon_poly
    2: Outfitting
    15: Group_Trapline
    16: Game_Management_SubzonesAnno
cheers,
matt wilkie
Geomatics Analyst
Information Management and Technology
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
> Reporter:  jpalmer            |        Owner:  osgeo4w-dev@…
>      Type:  task               |       Status:  closed
> Priority:  major              |    Component:  Package
>   Version:                     |   Resolution:  fixed
> Keywords:  ESRI FileGDB GDAL  |
> Changes (by warmerdam):
>   * cc: rburhum (added)
> Comment:
>   Done by Ragi (+rburhum).
>   Also note I added: [wiki:pkg-gdal-filegdb]
More information about the osgeo4w-dev mailing list
