[osgeo4w-dev] [osgeo4w] #272: osgeo4w - PROJ.4 strings do not work with GDAL
OSGeo4W trac_osgeo4w at osgeo.org
Wed Feb 22 18:39:52 EST 2012
Reporter:  tcgeophysics  |       Owner:  osgeo4w-dev@…
    Type:  defect        |      Status:  new
Priority:  major         |   Component:  Package
 Version:                |    Keywords:
 Hi All,
 I've using the OSGeo4W install of GDAL for a little while now and I just
 realized that GDAL utilities does not work when using PROJ.4 string to
 specify -s_srs or -t_srs.
 I usually defines my srs with EPSG codes and this does not give me any
 trouble. But I recently needed to use a custom projection and found out
 about the issue.
 I am running it with Windows 7 and I ran the commands in an OSGEO4w
 terminal window. The variables OSGEO4W_ROOT, PROJ_LIB and GDAL_DATA are
 pointing to the correct directories.
 If I enter the following command:
 ''gdalwarp -t_srs '+proj=utm +zone=11 +datum=WGS84' input.tif
 I get the following message:
 ''ERROR 1: Translating source or target SRS failed:
 '+proj=utm' ''
 Any idea on how to solve this?
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/272>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
