[osgeo4w-dev] ImportError: OSGeo4W problems with Python/GDAL
Casper Børgesen (CABO) CABO at NIRAS.DK
Wed Jun 13 00:53:21 PDT 2012
I'm aware of the difference in Python versions with OSGEO and my setup, but so far I have assumed that the solution to the problems related to the DLLs probably is the same regardless of the python/gdal version.
With regards to the VM, linux is not a solution a the moment - IT policies and so on :)
A follow up on topic:
I found that the two MSVCP100.dll and MSVCR100.dll is part of the Microsoft Visual C++ redistribution package and by installing that I actually got GDAL 1.9 and Python 3.2 to work with an empty PATH (except for my references to the network drive of course). Error references to IESHIMS.DLL in the Dependency Walker thus seems like being a wild chase.
My PATH contain references to:
\\drive\Python32
\\drive\GDAL19
I don't remember where I found the compilations of the two, but I haven't compiled them myself.
Now I need to find somewhere to create an installation of OSGEO to see if I can track down the problem there. Maybe it has something to do with the libeay32.dll (which in my case is related to GNU...something on the path) like Matt found out.
Thanks for your comments!
Regards Casper
-----Original Message-----
From: Alex Mandel [mailto:tech_dev at wildintellect.com]
Sent: 13. juni 2012 09:38
To: Casper Børgesen (CABO)
Cc: Matt Wilkie; osgeo4w-dev at lists.osgeo.org
Subject: Re: [osgeo4w-dev] ImportError: OSGeo4W problems with Python/GDAL
You're aware that OSGEO4w python gdal bindings are python 2.7 right? I haven't actually seen working in the wild python gdal with python 3+ (though it might exist, sounds like you might have built it).
As for dll madness, its often unclear what dll comes from where and what it does. I'm not surprised that random things conflict with no obvious reason.
Since you're using Virtual Machines, have you considered just using a linux VM, all this is pretty simple to setup under that. We even have one with all the goodies included http://live.osgeo.org
Enjoy,
Alex
On 06/13/2012 12:25 AM, Casper Børgesen (CABO) wrote:
> I finally got time to work on this problem again. Using the famous Dependency Walker, I found that on my local machine (which has a normal installation of GDAL 1.9 and Python3.2) that libeay32.dll also is part of the problem with importing GDAL, though here GDAL+Python actually works. That installation is not through OSGEO though!
> I have several virtual machines (various configurations) where I want to do some batch processing. I have placed Python 3.2 and GDAL 1.9 on a network path. Using a batch script I setup the PATH to point at the GDAL and the Python folder on the network drive. This leads me to the same problem as with OSGEO, though the dependency walker complains about MSVCP100.dll, MSVCR100.dll and IESHIMS.dll (Error opening file. The system cannot find the file specified (2).).
> From other posts I gather that the IESHIMS.dll file is related to Internet Explorer, but I fail to see what GDAL and IE has to do with each other. Thus I find it hard to determine what exactly that Dependency Walker is telling me.
> Exactly what folders is required on the PATH to get Python and GDAL to be able to work together? Import GDAL in the Python console only gives me "ImportError: DLL load failed: The specified module could not be found." while referring to '_gdal', which I guess is _gdal.pyd.
> I know that my approach is outside the OSGEO package at this point, but I think solving this problem can help me solve my original OSGEO installation problem.
> /Casper
> From: Matt Wilkie [mailto:matt.wilkie at gov.yk.ca]
> Sent: 9. maj 2012 19:47
> Cc: osgeo4w-dev at lists.osgeo.org
> Python/GDAL
> That's interesting. Today I get the same problem Casper reported. Yesterday I didn't; likely because I'd been running from a command shell several days old and it didn't have my current full system path in it.
> I eventually tracked it down to a certain dll in PATH, outside the osgeo4w tree: libeay32.dll. It's part of OpenSSL. Moving that external file elsewhere enabled python to carry on as normal.
> matt wilkie
> Geomatics Analyst
> Information Management and Technology
> Yukon Department of Environment
> 10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
> 867-667-8133 Tel * 867-393-7003 Fax
> http://environmentyukon.gov.yk.ca/geomatics/
> On 08-May-2012 10:21 AM, Matt Wilkie wrote:
> Hi Casper,
> I think you'll need to start from as clean an environment as possible and add items to path until things break again.
> For example, from a command shell (start > run > cmd.exe):
> :: clear whole PATH
> set path=
> :: clear PYTHONPATH, PYTHONHOME
> set pythonpath=
> set pythonhome=
> :: set basic o4w environment
> cd /d c:\osgeo4w
> set osgeo4w_root=%cd%
> path=%osgeo4w_root%\bin
> Now run python and import gdal.
> If it works, from the same command shell run each bat in "osgeo4w\etc\ini" and test the python import again until something fails.
> If it doesn't work, something is wrong with the current o4w package ecosystem and we'll try and dig it out.
> If you get through all the ini bat's without error, then the problem lies somewhere in the host Windows environment. Likely culprits include things like other python directories or .dll's in PATH, PYTHONPATH or PYTHONHOME (not necessarily gdal dll's).
> let us know how you make out,
> matt wilkie
> Geomatics Analyst
> On 07-May-2012 11:40 PM, Casper Børgesen (CABO) wrote:
> Hi!
> I am new to the GDAL world and I'm struggling with installing OSGeo4W to a working state.
> I have downloaded and installed the latest edition OSGeo4W. The
> install goes smoothly. I open the OSGeo4W Command shell and enter
> Python. I have seen that I can test the basic Python/GDAL binding(?)
> by entering
>>>> from osgeo import gdal
> This results in the following error:
> Traceback (most recent call last):
>   File "<stdin>", line 1, in <module>
>   File "C:\OSGeo4W\apps\Python27\lib\site-packages\osgeo\__init__.py",
> line 21, in <module>
>     _gdal = swig_import_helper()
> line 17, in swig_import_helper
>     _mod = imp.load_module('_gdal', fp, pathname, description)
> ImportError: DLL load failed: The operating system cannot run %1.
> I have read that this error might indicate that the installed python/gdal libraries are incompatible, but I'm wondering if my OSGeo4W installation is obstructed by another installation? The following three lines are added to my path by the OSGeo4W Command shell:
> C:\OSGeo4W\bin
> C:\OSGeo4W\\apps\msys\bin
> C:\OSGeo4W\\apps\Python27\Scripts
> I have searched through my system looking for gdal*.dll, but I have found none located within any of the folders in my PATH.
> What can I do to troubleshoot this problem?
> Regards, Casper
More information about the osgeo4w-dev mailing list
