[osgeo4w-dev] Re: new sqlite3, spatialite and freexl packages uploaded on server
Mon Mar 19 04:01:19 EDT 2012
On 12-03-18 07:37 PM, Giuseppe Sucameli wrote:
> Hi Frank, all
> I've uploaded 3 packages on the osgeo server:
> sqlite3-3.7.10-1, spatialite-3.0.1-1 and freexl-1.0.0b-1.
> The new sqlite shouldn't break anything, but anyway I hid it by putting the
> package to the /osgeo/download/release/sqlite3/test directory.
Guiseppe,
After a bit of testing of my own I have taken the liberty of promoting
this up and making it "official".
The spatialite and sqlite packages include static libraries (sqlite.lib
700K, and spatialite.lib 7MB) that I believe are unnecessary.  Could
you produce a new version of both packages without these?  People should
use the stub libraries which trigger use of the DLLs.
I discovered I had made the same mistake with PROJ.4 so I took this
opportunity to upgrade PROJ.4 to 4.8.0 and to modify the packaging
to avoid including the static proj.lib.
> Since the spatialite and freexl packages are new packages and cannot
> doing harm I kept them visible, they will become available after running
> the osgeo4w-regen.sh script.
I have also taken the opportunity to upgrade the GDAL 1.9 package to
include spatialite support and enabled the XLS driver using freexl.
Thanks for your good work!
Best regards,
light and sound - activate the windows | http://home.gdal.org/warmerda
and watch the world go round - Rush    | Geospatial Software Developer
More information about the osgeo4w-dev mailing list
