[osgeo4w-dev] osgeo4w-dev Digest, Vol 64, Issue 6
Ian Jones imjnes77 at gmail.com
Wed Apr 10 12:27:35 PDT 2013
Hi Alex,
Thanks for replying. Yes, I have Administrator access, I have tried it with
2 different accounts and in a completely different session as well. Without
any other apps on it. The local IT guy has looked at it as well but
none-the-wiser. I have been able to install it ok to Windows 7 on a
non-virtual, normal laptop.
Regards
Ian
On 10 Apr 2013 20:00, <osgeo4w-dev-request at lists.osgeo.org> wrote:
> Send osgeo4w-dev mailing list submissions to
>         osgeo4w-dev at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         osgeo4w-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of osgeo4w-dev digest..."
> Today's Topics:
>    1. Re: Cannot install OSGeo4W in Windows 7 VDI session -
>       'Program too big to fit in memory' (Alex Mandel)
> Message: 1
> Date: Wed, 10 Apr 2013 08:55:21 -0700
> From: Alex Mandel <tech_dev at wildintellect.com>
> To: osgeo4w-dev at lists.osgeo.org
> Subject: Re: [osgeo4w-dev] Cannot install OSGeo4W in Windows 7 VDI
>         session - 'Program too big to fit in memory'
> Message-ID: <51658B69.6080109 at wildintellect.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> On 04/10/2013 03:43 AM, Ian Jones wrote:
> > Hi all,
> > Has anyone else had the same experience? I've just downloaded the OSGeo4W
> > Installer but when I double-click the exe file to run it and attempt to
> > install it, nothing happens. If I drop it into a Command Line session, it
> > returns the above message.
> > I have 40Gb disk space, 4Gb of RAM so don't quite understand why it isn't
> > playing ball. I am trying to do this in Windows 7 Enterprise in a VM Ware
> > View Client v5.1.1.
> > Has anyone successfully got it installed to a virtual environment?
> > Much appreciated,
> > Regards,
> > Ian
> Have you tried running as Administrator?
> Virtual Environment should not be an issue.
> Thanks,
> Alex
> End of osgeo4w-dev Digest, Vol 64, Issue 6
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20130410/12adb539/attachment.html>
More information about the osgeo4w-dev mailing list
