[osgeo4w-dev] Testing OSGeo4W 64bit
Lord Flaubert Steve Ataucuri Cruz lord.ataucuri at ucsp.edu.pe
Mon Aug 26 18:23:13 PDT 2013
Jürgen,
It is strange it doesn't work for me, What is setup.ini file that you are
using? it looks like installer of 64bit version is using setup.ini file
from osgeo4w  32bit version without license entries in setup.ini file.
On the other hand I would like to use the changes of genini script of 64bit
version that you added for osgeo4w 32bit version in order to add license
entries for setup.ini file in server. Do you have the script updated and
how did you do it? I see license.map and chklicense files. We need to add 3
or 4 packages with non-opensource licenses.
Best
Steve
2013/8/26 Jürgen E. <jef at norbit.de>
> Hi Steve,
> On Mon, 26. Aug 2013 at 17:46:14 -0500, Lord Flaubert Steve Ataucuri Cruz
> wrote:
> > It seems the installer doesn't show the licenses features. I would like
> to
> > know how to test it.
> Hm, selecting gdal-ecw, gdal-mrsid, gdal-filegdb, oci or oci-devel should
> trigger the license download and display.   Works for me here.
> Maybe the debug output in dbgview helps to diagnose ([1]; started as admin
> as
> the installer also runs with elevated privileges).
> What I noticed is that updates are apparently not picked up anymore (eg.
> GEOS
> 3.4.2).
> Jürgen
> [1] http://technet.microsoft.com/en-us/sysinternals/bb896647.aspx
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Steve Ataucuri Cruz
School of Computer Science,
San Pablo Catholic University - Arequipa, Peru (http://www.ucsp.edu.pe),
Screen Names :
 stonescenter at hotmail.com (Windows Live Messenger)
 stonescenter at gmail.com (Google talk)
 stonescenter at yahoo.com (Yahoo Messenger)
 stonescenter (Skype)
+51.972529201 (Mobile)
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20130826/88c85faa/attachment.html>
More information about the osgeo4w-dev mailing list
