[osgeo4w-dev] OSGeo4W-64bit: qgis 2.4 - GRASS raster can't be loaded
Helmut Kudrnovsky
hellik at web.de
Sun Jul 6 00:34:25 PDT 2014
Jürgen E. Fischer wrote
> On Sat, 05. Jul 2014 at 23:48:37 -0700, Helmut Kudrnovsky wrote:
>> opening GRASS mapset in qgis 2.4, then load a GRASS raster, following
>> error
>> message pops up:
>> warning: projection can't be determined
>> modul can't be executed
>> command C:/OSGEO~1/apps/qgis/./grass/modules/qgis.g.info info=proj
> <br>
> <br>
>> but the file is there
>> C:\OSGeo4W64\apps\qgis\grass\modules\qgis.g.info.exe
>> any idea?
> Not really. I can open the gtopo30 map from the qgis_sample_data set just
> fine.
> Jürgen
qgis-common installation fails with:
Package: qgis-common
qgis-common.bat exit code -1073741515
when trying qgis-dev, I'm getting similar error.
looking in the log:
2014/07/06 09:26:53 error: Environment variable 'PATH' length exceeds 1024;
running with %WINDIR%\system32;%WINDIR%;%WINDIR%\wbem
2014/07/06 09:26:54 Extracting from
file://C:\softwareadd\osgeo4w\bit64/http%3a%2f%2fdownload.osgeo.org%2fosgeo4w%2f/x86_64/release/qgis/qgis-dev/qgis-dev-2.5.0-9.tar.bz2
2014/07/06 09:30:48 running: cmd.exe /c
"C:\OSGeo4W64\\etc\postinstall\qgis-dev.bat"
2014/07/06 09:30:54 abnormal exit: exit code=-1073741515
any idea?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/OSGeo4W-64bit-qgis-2-4-GRASS-raster-can-t-be-loaded-tp5149806p5149810.html
Sent from the osgeo4w-dev -- OSGeo Win32 Installer List mailing list archive at Nabble.com.
More information about the osgeo4w-dev
