[osgeo4w-dev] [osgeo4w] #420: qgis-common.bat fails during postinstall
OSGeo4W trac_osgeo4w at osgeo.org
Mon Jul 7 02:42:14 PDT 2014
Reporter:  jphespanha  |        Owner:  osgeo4w-dev@…
    Type:  defect      |       Status:  closed
Priority:  major       |    Component:  Installer
 Version:              |   Resolution:  fixed
Keywords:              |
Comment(by hellik):
 Replying to [comment:13 hellik]:
 > Replying to [comment:11 jef]:
 > > Replying to [comment:10 hellik]:
 > > > I've checked, both ms 64bit runtimes (2008, 2010) are installed on
 my box.
 > >Did you check with depends
 > opening crssync in dependency walker:
 > Error: At least one required implicit or forwarded dependency was not
 found.
 > QGIS_CORE.DLL, GDAL111.DLL, QTCORE4.DLL
 > but maybe it's because to be outside of a OSGeo4W session (?)
 ok manually added search path of the 3 dll's to the dependency walker test
 (C:\OSGeo4W64\bin and C:\OSGeo4W64\apps\qgis\bin), attached the log of
 this test.
 if I read the dependency walker correctly, there maybe some issues with:
 - ZLIB1.DLL (in OGDI.DLL and QTCORE4.DLL)
 - XERCES-C_3_1.DLL (in GDAL111.DLL; msvcr90.dll)
 - ICONV.DLL (msvcr80.dll)
 - SQLITE3.DLL (in QGIS_CORE.DLL, GDAL111.DLL, )
 - LIBCURL.DLL (in GDAL111.DLL)
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/420#comment:15>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
