[osgeo4w-dev] GDAL libs without Spatialite?
G. Allegri giohappy at gmail.com
Fri May 16 02:23:45 PDT 2014
I'm sorry for the buzz. I really don't know why but now it works, same
command, same origin. Don't know...
Thanks anyway Jurgen.
Giovanni
2014-05-16 11:12 GMT+02:00 Jürgen E. <jef at norbit.de>:
> Hi Giovanni,
> On Fri, 16. May 2014 at 10:39:09 +0200, G. Allegri wrote:
> > Running an ogr conversion I've noticed that GDAL 1.11 libs don't support
> > Spatialite DB creation.
> > #ogr2ogr -f SQLite mydata.sqlite mydata.shp -dsco "SPATIALITE=YES"
> > It outputs a simple Sqlite DB (FDO layers) but not a Spatialite DB.
> > Would it be possible to configure GDAL for it?
> Works fine here - and gdal111.dll is linked against spatialite4.dll in 32
> and
> 64bit.
> C:\OSGeo4W>set CPL_DEBUG=ON
> C:\OSGeo4W>ogr2ogr -f SQLite foo.sqlite d:\temp\ab.shp -dsco SPATIALITE=YES
> Shape: DBF Codepage = UTF-8 for d:\temp\ab.shp
> Shape: Treating as encoding 'UTF-8'.
> OGR: OGROpen(d:\temp\ab.shp/02C2C878) succeeded as ESRI Shapefile.
> SQLITE: SpatiaLite v4 DB found !
> OGR2OGR: 18 features written in layer 'ab'
> SQLITE: Error no such table: layer_statistics
> OGR: Unloading VirtualOGR module
> Shape: 18 features read on layer 'ab'.
> C:\OSGeo4W>ogrinfo foo.sqlite
> OGR: OGROpen(foo.sqlite/02BB85C8) succeeded as SQLite.
> INFO: Open of `foo.sqlite'
>       using driver `SQLite' successful.
> OGR: GetLayerCount() = 1
> 1: ab (Line String)
> Jürgen
> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
> Software Engineer         D-26506 Norden
> http://www.norbit.de
> QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20140516/8957ea07/attachment.html>
More information about the osgeo4w-dev mailing list
