[osgeo4w-dev] [osgeo4w] #464: Windows 64-bit installer does not include GRASS 7
OSGeo4W trac_osgeo4w at osgeo.org
Fri Apr 17 14:05:47 PDT 2015
Reporter:  pairmand                   |        Owner:  osgeo4w-dev@…
    Type:  defect                     |       Status:  closed
Priority:  major                      |    Component:  Installer
 Version:                             |   Resolution:  invalid
Keywords:  64-bit installer, GRASS 7  |
Comment(by wenzeslaus):
 You also have to also distinguish between 32/64 system and application.
 The page says that it will work ''for Windows XP through Windows 8 (both
 32 and 64 bit)'' but the application itself is just 32bit. If you think
 that it is too confusing, please propose better wording on grass-dev,
 grass-user, grass-web mailing list or preferably fill the ticket with
 proposed changes at http://trac.osgeo.org/grass/ as suggested.
Ticket URL: <http://trac.osgeo.org/osgeo4w/ticket/464#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
