[osgeo4w-dev] [Qgis-developer] QGIS Grass plugin 64 bit
Jürgen E. Fischer jef at norbit.de
Fri Dec 18 16:30:08 PST 2015
Hi Martin,
On Fri, 18. Dec 2015 at 18:11:54 +0100, Martin Landa wrote:
> 2015-12-18 15:44 GMT+01:00 Jürgen E. <jef at norbit.de>:
> > The grass plugin will be made with the release version of GRASS 7 (just like on
> > 32bit) - as soon as Martin Landa makes it available.
> currently you can test 64bit edition by installing `grass-daily`
> package. The first GRASS version uploaded as 32bit and 64bit package
> will be 7.0.3 which should be released in the middle of January [1].
Does that mean you're going to provide a 64bit grass 7.0.2 on the weekend or
that you changed your mind about it?
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20151219/10237531/attachment.sig>
More information about the osgeo4w-dev mailing list
