[osgeo4w-dev] SQLITE FTS4 unicode61 tokenizer
Denis Rouzaud denis.rouzaud at gmail.com
Thu Jul 30 05:26:46 PDT 2015
OK, tested on x86 and x64, it works perfect.
Thanks a lot Jürgen!
On 07/30/2015 11:52 AM, Jürgen E. Fischer wrote:
> Hi Denis,
> On Thu, 30. Jul 2015 at 11:03:49 +0200, Denis Rouzaud wrote:
>> For a QGIS plugin (quickifinder [0]), I am using FTS in SQLite.
>> While trying to use unicode61 tokenizer, I get a python error:
>> OperationalError: unknown tokenizer: unicode61
>>  From sqlite.org documentation [1], unicode61 is available from
>> version 3.7.13.
>> I tried with the installed Osgeo4w package, SQLite is at 3.7.17.
>>  From a quick googling, there is an option at compilation for this
>> tokenizer:
>> SQLITE_ENABLE_FTS4_UNICODE61
>> Is is enabled in Osgeo4w?
>> If not, is there any reason?
>> If not, would there be a chance to enable it?
> from #qgis:
> <drouzaud> jef: would it be ok for you to add -DSQLITE_ENABLE_FTS4_UNICODE61
> <drouzaud> ?
> <jef> drouzaud: no idea - what does it do?
> <drouzaud> jef: it's for a tokenier in full text search
> <drouzaud> https://www.sqlite.org/fts3.html#tokenizer
> <sigq> Title: SQLite FTS3 and FTS4 Extensions (at www.sqlite.org)
> <drouzaud> jef: better handling of latin languages
> <jef> drouzaud: try 3.1.17-2 please
> Jürgen
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20150730/9a4a9809/attachment.html>
More information about the osgeo4w-dev mailing list
