[osgeo4w-dev] apt 0.3-1 test release
Matt Wilkie
maphew at gmail.com
Fri Mar 6 16:58:05 PST 2015
Hi Folks,
I've uploaded a new apt.exe release, so far only in testing.To install or
upgrade use "setup-test.bat" to use regular installer and/or apt itself.
For the latter:
Download test ini:
wget http://download.osgeo.org/osgeo4w/x86/setup_test.ini
Run:
apt -i setup_test.ini new
...which should report:
The following packages are newer than the installed version:
apt 0.3-1
Then run:
apt -i setup_test.ini upgrade
Which should emit:
Fetching http://download.osgeo.org/osgeo4w/x86/release/apt/apt-0.3-1.tar.bz2
...100% D:/xxxxx//var/cache/setup/http%3a%2f%2fdownload.osgeo.org
%2fosgeo4w/x86/release/apt/apt-0.3-1.tar.bz2
e6f900c62b4cbee1c4092e1d1d8244d1 apt-0.3-1.tar.bz2 - remote
e6f900c62b4cbee1c4092e1d1d8244d1 apt-0.3-1.tar.bz2 - local
preparing to replace apt 0.0-8
removed: D:\xxxxx\bin\apt.bat
removed: D:\xxxxx\bin\apt-dev.py
removed: D:\xxxxx\bin\apt-r1193M.exe
warning: D:\xxxxx\etc\postinstall\apt.bat no such file
installing apt 0.3-1
You might need to manually delete "D:\xxxxx\bin\apt.exe"
If upgrade is successful it should report "-={ 2015-03.dev }=-" when
executed.
cheers,
Matt
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20150306/d05452a0/attachment.html>
More information about the osgeo4w-dev
