[osgeo4w-dev] [osgeo4w] #474: Outdated CA Certificates
OSGeo4W trac_osgeo4w at osgeo.org
Mon Nov 2 10:42:16 PST 2015
Reporter:  maphew  |      Owner:  osgeo4w-dev@…
    Type:  defect  |     Status:  new
Priority:  major   |  Component:  Package
 Version:          |   Keywords:  curl, openssl
 I believe either [wiki:pkg-curl], or more likely [wiki:pkg-openssl] have
 outdated CA Certificates, because downloading new certificates and
 pointing curl at them resolves `error:14090086:SSL
 routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed`
 Demonstrate error:
 C:\OSGeo4W>curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
 curl: (60) SSL certificate problem, verify that the CA cert is OK.
 Details:
 error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify
 failed
 More details here: http://curl.haxx.se/docs/sslcerts.html
 curl performs SSL certificate verification by default, using a "bundle"
  of Certificate Authority (CA) public keys (CA certs). The default
  bundle is named curl-ca-bundle.crt; you can specify an alternate file
  using the --cacert option.
 If this HTTPS server uses a certificate signed by a CA represented in
  the bundle, the certificate verification probably failed due to a
  problem with the certificate (it might be expired, or the name might
  not match the domain name in the URL).
 If you'd like to turn off curl's verification of the certificate, use
  the -k (or --insecure) option.
 Demonstrate workaround:
 C:\OSGeo4W>curl http://curl.haxx.se/ca/cacert.pem -o ca-bundle.crt
   % Total    % Received % Xferd  Average Speed   Time    Time     Time
 Current
                                  Dload  Upload   Total   Spent    Left
 Speed
 100  250k  100  250k    0     0   178k      0  0:00:01  0:00:01 --:--:--
 255k
 --cacert ca-bundle.crt
 Current
 Speed
 100 1379k  100 1379k    0     0   319k      0  0:00:04  0:00:04 --:--:--
 701k
 I'm not sure what the appropriate is folder to put the updated `ca-
 bandle.crt` in so the problem is fixed permanently. There is
 `C:\OSGeo4W\apps\Qt4\certs` but something like `etc/pki/tls...` or
 `apps/openssl` looks more "system" and not qt-app specific.
 Sources:
  - http://stackoverflow.com/a/30728558/14420
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/474>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
