[osgeo4w-dev] Including gvSIG on OSGeo4W
Jürgen E. Fischer jef at norbit.de
Thu Nov 26 08:32:35 PST 2015
Hi César,
On Thu, 26. Nov 2015 at 17:14:56 +0100, César Martínez wrote:
> Thanks Jürgen for the quick answer. Some more questions:
> - Where can I check which packages are currently included (e.g. the
> Java packages you mentioned)?
There is a package listing on https://trac.osgeo.org/osgeo4w/wiki/PackageListing
The generated lists are produced from the setup.ini that is created from the
setup.hint files that go along with the package files.
Those are in http://download.osgeo.org/osgeo4w/x86/setup.ini for 32bit and
http://download.osgeo.org/osgeo4w/x86_64/setup.ini for 64bit.  That also
includes on what other packages each packages depends.
PackagingInstructions also have instructions how to invoke the setup.ini
updates.
> - Is it necessary a new version of OSGeo4W needed in order to add the
> gvSIG packages? Or are they automatically available if published on
> the OSGeo4W repository?
No, adding the packages and updating the setup.ini should be enough.  The
installer retrieves that current setup.ini and works with it.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20151126/ba902b09/attachment.sig>
More information about the osgeo4w-dev mailing list
