[osgeo4w-dev] GDAL/OGR 2.0 in OSGeo4W
Jürgen E. Fischer jef at norbit.de
Sat Feb 20 05:03:14 PST 2016
Hi Hugo,
On Fri, 12. Feb 2016 at 08:53:44 +0100, Hugo Mercier wrote:
> > Just that everthing requiring GDAL 1.11 needs to be rebuilt to make use of
> > it.  I'm going to do the switch before the next QGIS point release (2.8,
> > 2.14).
> Cool, good to know !
The switch is done - and qgis-dev, qgis-rel-dev and qgis-ltr-dev are now
rebuilt with GDAL 2.0.2.
> > To play now one could also rename the gdal200.dll to gdal111.dll.
There now also is an experimental gdal111dll package (2.0.2-1) that has a
renamed GDAL 2.0.2 DLL inside.
The current gdal111dll package however contains gdal111.dll from the previous
GDAL main package.  It will be automatically installed when GDAL is updated -
so everything that used to depend on the previous GDAL should still work.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20160220/ad6caa8e/attachment.sig>
More information about the osgeo4w-dev mailing list
