[osgeo4w-dev] [osgeo4w] #466: Python stopped working when using python gdal_calc and band.ReadAsArray() on Windows
OSGeo4W trac_osgeo4w at osgeo.org
Thu Sep 1 14:06:55 PDT 2016
on Windows
Reporter:  miro         |       Owner:  osgeo4w-dev@…
    Type:  defect       |      Status:  new
Priority:  major        |   Component:  Package
 Version:               |  Resolution:
Keywords:  gdal python  |
Comment (by mcserep):
 Replying to [comment:7 ascarth]:
 > This seems to be an issue with how GDAL has been built for OSGeo4W, or
 the Python version, but not with GDAL itself. I have found that python
 will crash using the OSGeo4W Shell, but not when using GDAL installed
 through [https://www.continuum.io/downloads Conda]. Both installations are
 using GDAL 2.1.0. The only other difference is that Conda uses Python
 2.7.12 and OSGeo4W uses Python 2.7.5
 Since this is the website of OSGeo4W, I think this is still a valid and
 urgent bug report, and it is really disappointing how it lacks the
 required attention. By the way I faced the same bug when I used the GDAL
 binaries from [http://gisinternals.com/ GISInternals].
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/466#comment:8>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
