[osgeo4w-dev] null grid missing from PROJ 5 package
Kristian Evers kreve at sdfe.dk
Wed Apr 18 02:11:16 PDT 2018
Ah yes, I see. I guess that is where the problem arises. It only installs the init-files since the various grids have been moved to the proj-datumgrid package. The current proj-datumgrid package in OSGeo4W is at version 1.5 and it doesn't include the null grid. If the proj-datumgrid package is updated to version 1.6 or 1.7 the problem should be solved. Do you mind doing that, Jürgen?
/Kristian
-----Oprindelig meddelelse-----
Fra: Jürgen E. Fischer [mailto:jef at norbit.de]
Sendt: 18. april 2018 10:45
Til: Kristian Evers <kreve at sdfe.dk>
Cc: osgeo4w-dev at lists.osgeo.org
Emne: Re: [osgeo4w-dev] null grid missing from PROJ 5 package
Hi Kristian,
On Wed, 18. Apr 2018 at 08:31:59 +0000, Kristian Evers wrote:
> It is not clear to me why that has changed. I guess the intention is that
> everything in share/proj is included in the archive. I can't see from the
> build script how share/proj is populated though, so something may have gone
> wrong in that step. Maybe you can clear that up, Jürgen?
package.cmd runs install-all from makefile.vc with INSTDIR set to the current
directory, which runs install-all from nad/makefile.vc, which copies the file
to PROJ_LIB_DIR, which is $(INSTDIR)\SHARE.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
More information about the osgeo4w-dev mailing list
