[osgeo4w-dev] Upcoming PROJ 5.0.0 release
Kristian Evers
kreve at sdfe.dk
Mon Feb 19 09:31:19 PST 2018
> On 19 Feb 2018, at 16:49, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Kristian,
> On Mon, 19. Feb 2018 at 14:52:16 +0000, Kristian Evers wrote:
>> As you may know, a new version of the PROJ library is about to be released.
>> At the moment we are on release candidate 3 [0]. It is very likely that this
>> release candidate will be promoted to the final release. Before that happens
>> though, I want to make sure that everything works as expected in OSGeo4W. I
>> still haven't received any feedback on the release candidates from Windows
>> users though. Could someone please test that the release candidate builds and
>> works as expected in the OSGeo4W environment?
> 5.0.3RC3-1 is packaged for testing. Seems to work as a drop in replacement of
> 4.9.3. Should there be ABI incompabilities?
Thanks Jürgen!
The changes are add-ons compared to previous releases so there should be no incompatibilities. Although as a matter of principle the so-versions has been bumped because we are doing a major release. In a years time version 6 will be released which WILL break stuff. This is also announced in the release notes for version 5, but just an additional heads up since it probably will cause some pain in the future (hopefully not that much).
I have just done a few tests with QGIS and on the surface it looks fine. The only thing that I noticed was that in the QGIS about dialog the “PROJ.4” Version is set to 4.9.3, which obviously should be 5.0.0 in this case. Additionally the "PROJ.4” should be changed to “PROJ” (as per the release notes). I’ll report this back to the QGIS-dev list as well.
/Kristian
> Jürgen
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> osgeo4w-dev mailing list
> osgeo4w-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev
