[osgeo4w-dev] [osgeo4w] #554: saga-ltr pkg creates link without icon in start menu and desktop
OSGeo4W trac_osgeo4w at osgeo.org
Thu Jan 25 08:43:56 PST 2018
Reporter:  andreaerdna  |      Owner:  osgeo4w-dev@…
    Type:  defect       |     Status:  new
Priority:  minor        |  Component:  Package
 Version:               |   Keywords:  saga-ltr
 saga-ltr pkg (2.3.2-2) postinstall batch file fails to add start menu and
 desktop links with properly set icons (the links are created with blank
 icons) because incorrect use of double quotes with nircmd command.
 In etc\postinstall\saga-ltr.bat there is only one double quote after
 ''exec hide'' but we need to put two double quote in order to let nircmd
 do its job correctly.
 To solve the problem, the following lines in saga-ltr.bat
 if not %OSGEO4W_DESKTOP_LINKS%==0 nircmd shortcut
 "%OSGEO4W_ROOT%\bin\nircmd.exe" "%OSGEO4W_DESKTOP%" "SAGA GIS (2.3.2)"
 "exec hide "%OSGEO4W_ROOT%\bin\saga-ltr_gui.bat""" "%OSGEO4W_ROOT%\apps
 \saga-ltr\saga_gui.exe"
 if not %OSGEO4W_MENU_LINKS%==0 nircmd shortcut
 "%OSGEO4W_ROOT%\bin\nircmd.exe" "%OSGEO4W_STARTMENU%" "SAGA GIS (2.3.2)"
 need to be replaced respectively with the following lines
 "exec hide ""%OSGEO4W_ROOT%\bin\saga-ltr_gui.bat""" "%OSGEO4W_ROOT%\apps
 or (using nircmd special string sequence ~q) with
 "exec hide ~q%OSGEO4W_ROOT%\bin\saga-ltr_gui.bat~q" "%OSGEO4W_ROOT%\apps
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/554>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
