[osgeo4w-dev] QGIS 3 custom widgets missing in designer
Frank Broniewski hallo at frankbroniewski.com
Thu May 10 00:28:17 PDT 2018
Hi Andreas,
thank you very much for your feedback. I should have mentioned that I launched Designer with the qgis-designer.bat. I just checked on my laptop and there I have the QGIS widgets, so I just suppose that my installation is broken and I am going to do a fresh install. Might be quicker than looking for the cause 😉
Thanks again,
Frank
Dipl. Geogr. Frank Broniewski
Waldhölzbacher Str. 51
66679 Losheim am See
06872 509 068 4
0176 611 26 9 2 6
www.frankbroniewski.com
-----Ursprüngliche Nachricht-----
Von: osgeo4w-dev <osgeo4w-dev-bounces at lists.osgeo.org> Im Auftrag von Müller, Andreas, Dr. phil.
Gesendet: Mittwoch, 9. Mai 2018 23:26
An: osgeo4w-dev at lists.osgeo.org
Betreff: Re: [osgeo4w-dev] QGIS 3 custom widgets missing in designer
Hi Frank,
nice to here from you!
So much changed with QGIS3, QT5, PyQt5...
First, call qgis-designer.bat to start designer (i dont installed designer with QGIS3, so please try it)
Second, there is a qt.conf file, which is modified/copied by the batch file qt5_env.bat, check if it looks correct
If you are working with python, check if a qt.conf is also under apps\Python36
This also worked for qgis2 (not needed if  QT_PLUGIN_PATH is set?)
- make sure, that qgis_customwidgets.dll is under [osgeo4w]\apps\Qt5\plugins\designer, if not copy it from [osgeo4w]\apps\qgis\qtplugins\designer
- in disigner i had to use menu command help->plugins and reload to to see all custom widgets
Good luck and have a nice "fathers day"
Greetings from Trier,
Andreas
Dr. Andreas Müller -_- Universität Trier - FB VI - Kartographie, muellea at uni-trier.de
54286 Trier, Behringstr. 29, F 191, ++496512014576
________________________________________
Von: osgeo4w-dev <osgeo4w-dev-bounces at lists.osgeo.org> im Auftrag von Frank Broniewski <hallo at frankbroniewski.com>
Gesendet: Mittwoch, 9. Mai 2018 16:25
Betreff: [osgeo4w-dev] QGIS 3 custom widgets missing in designer
I am missing the QGIS 3 custom widgets in Designer, the standard widgets are there though. Any ideas? QGIS (2) widgets from LTR are in Designer though …
Frank
06872 509 068 4
0176 611 26 9 2 6
osgeo4w-dev mailing list
https://lists.osgeo.org/mailman/listinfo/osgeo4w-dev
More information about the osgeo4w-dev mailing list
