[osgeo4w-dev] WinGRASS build up (WIP)
Jürgen E. Fischer jef at norbit.de
Tue Nov 5 09:56:37 PST 2019
Hi Helmut,
On Tue, 05. Nov 2019 at 18:30:18 +0100, Helmut Kudrnovsky wrote:
> >Any idea when GRASS will be updated with the new dependencies?
> see https://github.com/OSGeo/grass/pull/136#issuecomment-547497328
> "Sure it is still GDAL2"
> is OSGeo4W still default in gdal2/proj5? is gdal3/proj6 still in OSGeo4W experimental/testing?
I went ahead an did all what is proposed there and now you can build GRASS with
GDAL3 and PROJ6 using the "experimental" packages.  Once that's done we can
flip the switch and take all the "experimental" packages live - they are only
waiting for GRASS.
> in #136, environment is pointing to gdal-dev proj-dev, which I assume is gdal3/proj6, right?
No, GDAL master (3.1 2b) and PROJ master (7.0 2b).   And #136 is for master
(ie. grass-daily)
#137 was for the release branch and was merged.
> GRASS is in a RC cycle for GRASS 7.8.1: RC1
With #118 merged - so it should already work with GDAL3 and PROJ6.
> a possible workflow may be (?):
> (1) update/adapt #136 to reflect a default gdal3/proj6 in OSGeo4W
> (2) apply updated PR to issue a GRASS 7.8.1 RC2
> (3) switch OSGeo4W to a default gdal3/proj6
> (4) binary release GRASS 7.8.1 RC2 in OSGeo4W
Or just build GRASS with the "test" packages, upload it and then we can remove
all the "experimental" tags.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20191105/627b1c78/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20191105/627b1c78/attachment.ksh>
More information about the osgeo4w-dev mailing list
