[osgeo4w-dev] QGIS failed to start because QT platform plugin
Jürgen E. Fischer jef at norbit.de
Mon Aug 24 07:56:02 PDT 2020
Hi Pedro,
On Mon, 24. Aug 2020 at 14:13:48 +0100, Pedro Venâncio wrote:
> Just for future reference, the issue was with C:\Program Files\RStudio\bin
> where there are some QT dlls.
> Path to RStudio is only present in ..-g7.env files. Are they necessary for
> anything?
Those come from the rbatch package - which is a grass dependency.  See
https://trac.osgeo.org/osgeo4w/wiki/pkg-rbatch.
It should probably be optional and be sourced in the grass$V.bat or GRASS'
env.bat instead and not from etc/ini.
Did you install GRASS later?  If you installed it with QGIS it should have
affected both QGIS w/ and w/o GRASS.  I guess .env for QGIS w/o GRASS was
created clean because rbatch was not present yet.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden            https://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20200824/08a63f88/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20200824/08a63f88/attachment.ksh>
More information about the osgeo4w-dev mailing list
