[osgeo4w-dev] [osgeo4w-setup-x86_64][Question] CLI is skipping the parameters?
Stefan Blumentrath Stefan.Blumentrath at nina.no
Mon Mar 2 00:23:32 PST 2020
Hi Joao,
This is how I use to download and create a local installation repo:
osgeo4w-setup-x86_64 -q -a x86_64 -g -k -S -l "R:\\Program\\QGIS-OSGeo4W\\QGIS3_packages" -D -P avce00 -P boost -P boost-devel -P boost-libs -P cairo -P curl -P eigen -P expat -P ffmpeg -P fftw -P flann -P fltk -P freeglut -P freetype-devel -P freetype-vc-devel -P freexl -P fribidi -P gdal -P gdal-ecw -P gdal-filegdb -P gdal-mrsid -P gdal-mss -P gdal-oracle -P gdal-python -P gdal-sosi -P geos -P glew -P glext -P glfw -P gpsbabel -P gpsbabelfe -P grass -P gs -P gsl-devel -P gsl-libs -P hdf4 -P hdf5 -P hexer -P iconv -P iconv-vc14-devel -P icu-devel -P itk -P java -P laszip -P libcairo -P libgeotiff -P libjpeg -P libjpeg12 -P libkml -P liblas -P …..
And then to install:
osgeo4w-setup-x86_64.exe -q -k -g -A -d -a x86_64 --local-install --root "C:\\Programs\\OSGeo4W" -l "R:\\Program\\QGIS-OSGeo4W\\QGIS3_packages" -C Libs -C Commandline_Utilities -C Desktop
Hope that helps a bit.
Cheers
Stefan
From: osgeo4w-dev <osgeo4w-dev-bounces at lists.osgeo.org> On Behalf Of João Gaspar
Sent: fredag 28. februar 2020 16:04
To: osgeo4w-dev at lists.osgeo.org
Subject: Re: [osgeo4w-dev] [osgeo4w-setup-x86_64][Question] CLI is skipping the parameters?
So let me do an update.
I remove the fresh installation and package and the script run as expected with the following behaviours:
Show me a dialogue only with downloading the packages and close after download but the following packages aren't downloaded:
"gdal-oracle"
"gdal-mrsid"
"gdal-ecw"
"gdal-mss"
"gdal-filegdb"
"grass"
"saga-ltr"
But if I open using setup GUI with the same mirror I can see the packages and I can download. For gdal "extensions" I probably point for some kind of issue with the flag --auto-accept but involve grass and saga-ltr...
I will wait for some feedback.
Regards,
João
João Gaspar <joao.f.r.gaspar at gmail.com<mailto:joao.f.r.gaspar at gmail.com>> escreveu no dia sexta, 28/02/2020 à(s) 14:07:
Hi Devs,
I'm working a PowerShell script using OSGeo4W Network Installer to download specific packages in quiet-mode from a mirror and save locally.
What is happening is that we run but don't respect the parameter --quiet-mode, --no-desktop and don't download the specific packages. Only download the installer and the setup.ini
This script is based on this gist: https://gist.github.com/Guts/6303dc5eb941eb24be3e27609cd46985
and I'm following  the https://trac.osgeo.org/osgeo4w/wiki/CommandLine
Additional notes:
OS: Windows 10 Professional
I'm testing as Administrator.
Test with and without quotes (URL, packages) and the behaviour is the same.
I did the same install but with dialogs and the same packages and everything go right.
My changed script is actually like this:
# Save current working directory
$starter_path = Get-Location
# Move into the user download directory
Set-Location -Path "$env:USERPROFILE/Downloads"
# Download installer (storage standard installer)
Write-Host "= Start downloading the OSGeo4W installer" -ForegroundColor Yellow
Invoke-WebRequest -Uri "https://download.osgeo.org/osgeo4w/osgeo4w-setup-x86_64.exe" -OutFile "osgeo4w-setup-x86_64.exe"
# Download the packages included into the QGIS LTR Specific packages
Write-Host "== Installer downloaded into $env:USERPROFILE/Downloads" -ForegroundColor Yellow
Write-Host "== Start downloading the QGIS LTR " -ForegroundColor Yellow
.\osgeo4w-setup-x86_64.exe --quiet-mode --download --site "http://download.osgeo.org/osgeo4w" --no-desktop --advanced --arch x86_64 --autoaccept --packages "qgis-ltr" "qgis-ltr-grass-plugin7" "qgis-ltr-oracle-provider" "gdal-oracle" "gdal-mrsid" "gdal-ecw" "gdal-mss" "gdal-filegdb" "hdf4" "hdf5" "libmysql" "netcdf" "oci" "opencl" "grass" "saga-ltr" "otb-bin" "otb-ice" "otb-python" "python3-exifread" "python3-h5py" "python3-pip" "python3-plotly" "python3-scipy" "python3-numpy" "python3-matplotlib" "python3-pyopengl" "python3-pyodbc" "ffmpeg" | out-null
Did I do something wrong?
Best regards,
João Gaspar
URL: <http://lists.osgeo.org/pipermail/osgeo4w-dev/attachments/20200302/e7377b71/attachment-0001.html>
More information about the osgeo4w-dev mailing list
