[osgeo4w-dev] [osgeo4w] #649: Installing Fiona, Geopandas or rasterio using OSGeo4W breaks QGIS python
OSGeo4W trac_osgeo4w at osgeo.org
Mon Nov 9 02:48:43 PST 2020
Reporter:  cratcliff                |       Owner:  osgeo4w-dev@…
    Type:  defect                   |      Status:  new
Priority:  critical                 |   Component:  Package
 Version:                           |  Resolution:
Keywords:  fiona geopanda rasterio  |
Comment (by jef):
 Quick workaround: create an empty directory .libs in
 {{{%OSGEO4W_ROOT%\apps\Python37\lib\site-packages\fiona}}} and
 {{{%OSGEO4W_ROOT%\apps\Python37\lib\site-packages\rasterio}}} or change
 {{{%OSGEO4W_ROOT%/apps/qgis/python/qgis/utils.py}}} by adding {{{and
 os.path.isdir(p)}}}:
 diff --git a/python/utils.py b/python/utils.py
 index c2a403efec..6be762ced9 100644
 --- a/python/utils.py
 +++ b/python/utils.py
 @@ -780,7 +780,7 @@ def _import(name, globals={}, locals={}, fromlist=[],
 level=None):
                  global _RemoveDllDirectory
                  for p in set(new_path.split(';')) -
 set(old_path.split(';')):
 -                    if p is not None and p not in _import_path:
 +                    if p is not None and p not in _import_path and
 os.path.isdir(p):
                          _import_paths[p] = _AddDllDirectory(p)
                  for p in set(old_path.split(';')) -
 set(new_path.split(';')):
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/649#comment:1>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
