[osgeo4w-dev] [osgeo4w] #650: msodbcsql - unknown package
OSGeo4W trac_osgeo4w at osgeo.org
Wed Nov 11 17:11:39 PST 2020
Reporter:  tobwen  |       Owner:  osgeo4w-dev@…
    Type:  defect  |      Status:  new
Priority:  minor   |   Component:  Installer
 Version:          |  Resolution:
Keywords:          |
Comment (by jonnyforest):
 Hi guys,
 I had the same problem. I did e fresh install with OSGeo4W64 using UAC and
 and the log show:
 2020/11/11 09:34:46 running: cmd.exe /c
 "C:\OSGeo4W64\\etc\postinstall\msodbcsql.bat"
 2020/11/11 09:34:47 abnormal exit: exit code=1603
 I had as well the same issue in the commandline of osgeo shell-
 I went to the bin folder and did a manual install of msi (right-click open
 as administrator) and the problem was solved.
 If I try to install using the msiexec method I have the same problem of
 tobwen.
 I did a quick search about exit code=1603 and can be about permissions or
 corrupted .msi
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/650#comment:4>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
