[osgeo4w-dev] [osgeo4w] #687: Install specific package version via command line
OSGeo4W trac_osgeo4w at osgeo.org
Wed Jul 21 03:37:38 PDT 2021
Reporter:  peetwhittaker  |       Owner:  osgeo4w-dev@…
    Type:  enhancement    |      Status:  new
Priority:  minor          |   Component:  Installer
 Version:                 |  Resolution:
Keywords:                 |
Comment (by peetwhittaker):
 I just used that package as an example (we've already upgraded to 56.1-5 -
 thanks for the quick fix!).
 It would be useful in situations where the fix is not/cannot be deployed
 as quickly. It would also bring parity between the CLI and the GUI (where
 you **can** install the previous version).
 Perhaps the syntax could just be something like the following (again, just
 using {{{icu-libs}}} as an example):
 {{{--packages icu-libs=prev}}}
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/687#comment:2>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
