[osgeo4w-dev] [osgeo4w] #770: python3-rasterio broken in latest two releases
OSGeo4W trac_osgeo4w at osgeo.org
Sun Dec 11 16:10:14 PST 2022
Reporter:  cratcliff  |      Owner:  osgeo4w-dev@…
    Type:  defect     |     Status:  new
Priority:  critical   |  Component:  Package
 Version:             |   Keywords:  rasterio
 I get the following message when importing rasterio (1.3.3-2 and 1.3.3-1)
 import rasterio
   File "<stdin>", line 1, in <module>
   File "C:\PROGRA~1\QGIS32~1.3\apps\Python39\lib\site-
 packages\rasterio\__init__.py", line 28, in <module>
     from rasterio._version import gdal_version, get_geos_version,
 get_proj_version
 ImportError: DLL load failed while importing _version: The specified
 procedure could not be found.
 Probably related to changes in rasterio packaging
 (https://github.com/rasterio/rasterio/releases/tag/1.3.3,
 https://github.com/rasterio/rasterio/pull/2594)
 Is there a way to access older versions using command line installs until
 it gets fixed?
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/770>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
