[osgeo4w-dev] [osgeo4w] #772: LASzip is missing in lastools (e.g. las2las, lasinfo) in OSGeo4W Shell (Windows 11)
OSGeo4W trac_osgeo4w at osgeo.org
Wed Dec 14 05:46:11 PST 2022
(Windows 11)
Reporter:  Stefan Keller  |      Owner:  osgeo4w-dev@…
    Type:  defect         |     Status:  new
Priority:  major          |  Component:  Package
 Version:                 |   Keywords:  lastools, laszip
 ''(First issue submission was here
 https://github.com/qgis/QGIS/issues/51193 - now moved to the right pace
 here)''
 When running e.g. lasinfo or las2las in cmd-line / OSGeo4W Shell the
 following error occurs:
     error: Compression support not enabled in liblas configuration
 == Observations / Notes:
 I think LASzip is missing in the packaging/compliling.
 Running lasinfo or las2las in the cmd-line without params to show version
 header reveals:
     lasinfo (libLAS 1.8.1 with GeoTIFF 1.4.2)
 I expected:
     lasinfo (libLAS 1.8.1 with GeoTIFF 1.4.2, LASzip n.n.n.)
 What's also worth noting is that in bin (C:\Program Files\QGIS
 3.22.13\bin), there is laszip3.dll but no laszip.dll. Renaming doesn't
 help.
 == Steps to reproduce the issue
 Using QGIS 3.22.13 LTR or 3.28.1 (on Windows 11):
 1. Go to https://wheregroup.com/blog/details/visualisierung-und-
 manipulation-von-lidar-daten-mit-qgis-und-pdal/ and download the "LIDAR
 Testdaten aus OpeGeoData.NRW", unpack.
 2. Open OSGeo4W Shell and type "las2las" --> Check the header
 3. Paste the following into the command line:
 lasinfo 3dm_32_510_5704_1_nw.laz \\
 las2las 3dm_32_510_5704_1_nw.laz --output out.laz --extent "510100 5703500
 510900 5704500"
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/772>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
