[osgeo4w-dev] [osgeo4w] #796: qgis-common.bat exit code -1073741511
OSGeo4W trac_osgeo4w at osgeo.org
Fri Jun 23 08:42:59 PDT 2023
Reporter:  Antonio3Brandao  |      Owner:  osgeo4w-dev@…
    Type:  defect           |     Status:  new
Priority:  normal           |  Component:  Package
 Version:                   |   Keywords:  1073741511;gdal307.dll;
 Hello,
 System:Windows 10 64bit and QGIS3 using
 https://download.osgeo.org/osgeo4w/v2/osgeo4w-setup.exe
 Previous I had 3.18 installed and I installed QGIS version 3.30 along with
 the previous one and after the problem apear. After I remove the 3.18
 version.
 Error after uninstalling and installing again:
 Package: Unknown package
 [[Image(https://i.imgur.com/FhhhtuT.png)]]
 With Dialogue box with error:
 crssync.exe - Entry Point Not Found The procedure entry point
 opj_encoder_set_extra_options could not be located in the dynamic link
 library C:\OSGe04W\bin\gdal307.dll.
 [[Image(https://i.imgur.com/U5OlaE5.png)]]
 As search the problem could be because of missing the libcurl.dll, and I
 have in System32 folder and SysWOW64 only the libcurl769.dll that seems to
 be another version, and I copy libcurl.dll from QGIS3 into both system
 folder and problem is the same.
 Any help would be appreciated.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/796>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
