[osgeo4w-dev] [osgeo4w] #796: qgis-common.bat exit code -1073741511
OSGeo4W trac_osgeo4w at osgeo.org
Sat Jun 24 17:02:35 PDT 2023
Reporter:  Antonio3Brandao          |       Owner:  osgeo4w-dev@…
    Type:  defect                   |      Status:  new
Priority:  normal                   |   Component:  Package
 Version:                           |  Resolution:
Keywords:  1073741511;gdal307.dll;  |
Comment (by Antonio3Brandao):
 Hello hellik, sorry about the confusing describing the problem and also
 the attachments.
 I have to write everything all over again. I loose my comment to you when
 i was making attachments to the comment.
 Any way.
 I Have both openjpeg installed and I even downgrade the version without
 success.
 I don't know if I still have any traces of previous installations of
 openjpg or previous qgis versions.
 I would like to know how trace the windows PC for any previous versions
 like to reach the result jphespanha in the previous mention ticket above
 with the application event log:
 "And you are right with the "SidebySide" error. I checked the application
 event log at the server, and spotted this message: "Activation context
 generation failed for "C:\OSGEO4~1\bin\SSLEAY32.dll". Dependent Assembly
 Microsoft.VC90.CRT,processorArchitecture="amd64",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8"
 could not be found. Please use sxstrace.exe for detailed diagnosis." I
 will try the "dependency walker", but maybe there is already sufficient
 info to solve the situation."
 I was reading for solution and I decided to read off all qgis3, remove all
 Microsoft Visual C++ Redistributable packages restart the windows PC and
 install all it again, and no success.
 I pass the app dependency walker x64 and point me to errors on
 qgis_core.dll and gdal307.dll and  also to different versions of
 dependable files I think.
 See attachment that I put before the comment. All are the same file.
 Sorry, my confusion.
 And thanks for help.
Ticket URL: <https://trac.osgeo.org/osgeo4w/ticket/796#comment:9>
OSGeo4W <http://trac.osgeo.org/osgeo4w>
OSGeo4W is the Windows installer and package environment for the OSGeo stack.
More information about the osgeo4w-dev mailing list
